-   -   help w/ early turbo case (http://forums.pelicanparts.com/911-engine-rebuilding-forum/309397-help-w-early-turbo-case.html)
}{arlequin 10-13-2006 06:10 AM
this smooth compound that's to the left of the slotted screw... it's some kind of a patch. can anyone tell me what type of damage this could be hiding? there is no visible crack from the inside. does this mean the condition of this case is "terminal"? thanks.
http://forums.pelicanparts.com/uploa...1160744992.jpg
http://forums.pelicanparts.com/uploa...1160745018.jpg
cstreit 10-13-2006 06:45 AM
Sure looks like JBWeld.... Probably cracked or hit that side of the case. I guess the things I'd worry about it are:
1. Flow obstruction. You don't know how big the crack or hole is and therefore how much of the patch got pushed into the oil channel.
2. Will it break again?
If it were my engine I'd probably want to remove that crap and have a good aluminum welder make a more permanent repair. This certainly reduced the value of the case, but I doubt it's rendered unusable.
vanwyk4257 10-13-2006 02:36 PM
Dave, I'd say it's junk and you should sell it to me cheap! :)
mb911 10-13-2006 04:26 PM
send it to me I'll fix it along with jerry's/chris's 3.0 case
Henry Schmidt 10-13-2006 11:27 PM
There is a steel tube cast into the case under the aluminum at that point. A porous casting in this generally area are not uncommon and the factory recommended this type of repair. However it looks excessive. I would remove the adhesive (a propane torch will make it easy) access the damage and repair it if possible.
Without removing the adhesive there is no way to determine if it's repairable or not. My guess is that it will be repairable.
Good luck.
