Wine User
warner53's Avatar
Question Aluminum motor cases
Hi guys,
How do I know which engine cases are aluminum in the early cases (1965 to 1969)?
I am looking for a rebuildable aluminum motor.
Thanks you and porsche on.
Warner
Old 10-20-2006, 07:23 AM
Super Moderator
cstreit's Avatar
I'm sure someone can chime in here with case numbers, but you can tell easily by color. Once you've seen them both you can't miss it. Aluminum is a lighter silver color, magnesium is a dark grey.
Chris
1996 993 RS Replica
2023 KTM 890 Adventure R
1971 Norton 750 Commando
Alcon Brake Kits
Old 10-20-2006, 07:27 AM
I think all of the 68's and 69's are mag..
so your search is going to be more on the 65-67 cases.
914/6 2.0S with twin plug
all metal body panels
19quarts of oil
4 gallons of gas
and 1826 lbs (wet)
Old 10-20-2006, 08:07 AM
Wine User
warner53's Avatar
Hi,
Dempsey in his book suggested that the change was 1/2 way through 1968? Is there somewhere that I can find case numbers?
Thanks,
Porsche on!!!!
Warner
Old 10-20-2006, 10:39 AM
alum I.D.
The easiest way is to look at the engine on the bottom around the sump cover, the alum. cases have fins running almost the length of the case.
Mike Bruns
Old 10-20-2006, 12:22 PM
