-   -   996 Cranks but won't Start (http://forums.pelicanparts.com/911-engine-rebuilding-forum/310067-996-cranks-but-wont-start.html)
prmej 10-16-2006 07:18 PM
Porsche 996 cranks but won't start. After turning the ignition key on and off many times I could only hear the fuel pump prime once. Tried spaying starting fluid directly into the engine car cranks but not start.Any suggestions in trying to diagnose would be appreciated.
88911coupe 10-16-2006 08:06 PM
Well if it was one of our older cars I'd suspect the DME relay. If 996's use DME that's the pace to start.
You should probably try this question in the technical section as well.
