-   -   Twin plugging Motronic - Question (http://forums.pelicanparts.com/911-engine-rebuilding-forum/310132-twin-plugging-motronic-question.html)
Boxer 6 10-17-2006 07:40 AM
I am planning on bumping my compression ratio to 10.3:1 on my 87 3.2 during this winters rebuild. I will be getting the heads twin plugged as well. What options do I have as far as the ignition goes utilizing the stock Motronic fuel injection. Thanks for the replies in advance.
Steve@Rennsport 10-17-2006 08:25 AM
Mark:
The easiest and least expensive route to twin-ignition on a Motronic-equipped 3.2 is to install a 3.6 dual-distributor & plug wire harness, an extra stock coil, and the Andial Motronic splitter.
You need to install the 3.6 distributor crank gear as well but thats cheap.
cgarr 10-17-2006 08:48 AM
I didn't do that on mine, did I do something wrong? :eek:
Steve@Rennsport 10-17-2006 09:08 AM
You'll have more noise & backlash if you don't swap crank gears as these are matched parts. Its also possible that the brass crank gear might not last as long, too.
cgarr 10-17-2006 09:19 AM
Would you advise cracking it open for this or not? I have the time and the engine only has about 300 miles on it
MBruns 10-17-2006 09:25 AM
crank gears
Steve, the 3.2-3.6 (84-98) are the same for both dist. drive gear and the brass crank gear so he will be fine part #'s 930 602 424 00 is the dist gear, 930 102 112 00 is the crank gear,
We are building 12 pin dist for 911 engines 2.0-3.8 and have done alot of research on this. we also have some custom dist gears made that will tightem up the back lash common with even the new gears installed. we are doing both internal trigger and crank triggered versions.
Mike Bruns JBRacing.com
Boxer 6 10-17-2006 09:39 AM
Sounds like the hardest part of this conversion will be locating the parts. Thanks!
Steve@Rennsport 10-17-2006 12:39 PM
Hi Mark:
I have a good 3.6 dizzy here and the Andial splitter if you need it.
A good used coil is easy to source.
Steve W 10-17-2006 06:35 PM
Mark, in addition be sure to have a chip designed for the twin plug ignition setup as a 93 octane performance chip for a single plug application would have way too much ignition timing for the motor.
Henry Schmidt 10-17-2006 06:52 PM
Andial splitter and the Supertec twin plug distributor.
Looks great, works better. We can build the twin plug distributor using your stock 3.2 Carrera distributor. http://forums.pelicanparts.com/uploa...1161136292.jpg
Boxer 6 10-17-2006 07:32 PM
Hi Steve,
That would mean I need to buy another chip from you:D Thanks for the advise
Henry Schmidt 10-17-2006 07:39 PM
Re: crank gears
Originally posted by MBruns
............... we also have some custom dist gears made that will tightem up the back lash common with even the new gears installed........
What back lash?
You only get back lash if you miss match the early dist gear (2.0-2.7) with the late crank gear (3.2-2.6).
MBruns 10-17-2006 07:49 PM
back lash
You are fortunate, and I know the difference in the gears early vs. late. we see the timing wiggle on most all of them some up to 5-6 deg visible on the dyno with a timing light.
check a few distributors installed with a dial indicator at the tip of the rotor, and I dont mean the advance mech. or set one up in a case half before assy.
Carrera3.5L 10-17-2006 07:51 PM
Re: Twin plugging Motronic - Question
I've posted this before in other threads, but here is what I used for my conversion:
964/993 distributor (bought on ebay for $220, patience can be a virtue)
new dist. drive belt, vent kit, caps & rotors (so I had a maintenance baseline but you may not want/need to do this)
Andial signal splitter
2nd Bosch ignition coil (part number 944 602 115 00 or 00 055)
Custom fabricated alu bracket to hold both coils
Custom Magnecor wire set (just call them with wire lengths you require and they'll build to spec or simply make your own wire set)
2nd set of lower plugs (still use stock WR7DC)
Custom made nylon wire separators
Lower Plug hold-down clips (probably not necessary in most instances but looks nice)
Twin-plug heads & lower valve covers
http://forums.pelicanparts.com/uploa...1161139037.jpg
http://forums.pelicanparts.com/uploa...1161139103.jpg
http://forums.pelicanparts.com/uploa...1161139270.jpg
http://forums.pelicanparts.com/uploa...1161139418.jpg
The single distributor/cap/rotor looks clean as well, and maybe make it easier to pass a visual inspection for smog testing if needed? Although I haven't had a problem yet with the 964/993 distributor passing the visual either...
Figure on spending anywhere from $1,200 - $2,000 for the conversion pieces depending on how resourceful (or maybe lucky is a better term?) you are with parts availability/selection/negotiation...:)
One thing not mentioned and that you should know is that if using the 964/993 distributor with the stock heater blower tube, it will most likely interfere and you will have to "modify" the plastic tube to fit...in my case it was a non-issue... :)
Ralph
WydRyd 10-17-2006 08:31 PM
Henry, how much is this/your conversion?
I need to hook up my twin plugged heads too, but it seems my intercooler piping will interfere with the 964/993 distributor, so I need a more "compact" solution.
Boxer 6 10-18-2006 05:53 AM
I have the same question. I have seen the price of the cap and rotor:eek:
