CBRacerX's Avatar
Rod Interference with Oil Pump
OK, so I bought some R&R aftermarket rods for my 3.6->3.8 964 project. Doing a fit check tonight, I found that the rods interfere with the oil pump on the 3, 5 and 6 big ends. I've certainly heard of clearancing the pump before, but have not done so myself. Any tips, constructive thoughts, procedures and/or pictures?
Thanks! Would like to nail this down and keep the rebuild going!
Chris
https://dergarage.com
‘11 987.2 CS, '01 986S, '11 958S, '24 R1T, '87 Defender V8
Old 10-25-2006, 09:10 PM
MBEngineering's Avatar
HI is the rods in contact with the oil pump when the cylinder and piston is fitted?? or without, Just be careful removing anything of the oil pump as the case is not that thick!!!
regards mike
Old 10-26-2006, 11:43 AM
CBRacerX's Avatar
regards mike
Yes, the rods touch the oil pump case. In using Carillos for example, you must remove .5 mm from the oil pump case to fit the rods.
Chris
Old 10-26-2006, 12:59 PM
Loose nut bhind the wheel
Chris I think what Mike was saying is that if you are test fitting the rods without the cylinders and pistons (without rings) you may find clearance issues. The pistons and cylinders center everything properly.
Ed
1970 911S Targa 2.7RS MFI dual plug 10.5:1
1974 260Z SCCA ITS
1998 M3
Old 10-26-2006, 10:13 PM
CBRacerX's Avatar
I'm afraid I already thought of that before the post . This occurs with the P&C installed.
Chris
Old 10-27-2006, 03:37 AM
HI put some putty, plasticine or dum-dum in there on top of the pump, then refit and turn over, both ways to check how/where you will need to remove material and the depth to go to , off the rods if poss, which pump are you using as the mag Carrera 2/4 pump is very thin to set of with????
regards mike
Old 10-27-2006, 04:48 AM
CBRacerX's Avatar
Here are the interference points:
Chris
Old 10-27-2006, 11:45 AM
HI I would mod the rods for clearance and re balance for the amount to be taken off to clear, and you need to do something with your oil pump lock tabs if you are using them as thay are not locking the nut, either turn them 90 deg anti-clock wise, so the bottom tab is up against the pump case and cannot turn or use "schnorr" washers.
regards mike
Old 10-28-2006, 05:05 AM
