Help Identify these 80mm pistons
Can anyone identify these 80mm pistons?
They appear to be more aggressive than any of the 2.0 S pistons I've seen.
They look like the 906/910 racing pistons on page 140 in BA's book.
Can anyone help?
Tom Butler
1973 RSR Clone
1970 911E Restoration in Progress
Old 10-28-2006, 10:20 AM
Super Moderator
cstreit's Avatar
They sure look similar 906 pistons to me... but I'm just a schlub, I'd wait for the experts to chime in.
Chris
2001 GT3 Cup - "Pepin"
1999 Spec Miata
1996 993 RS Replica
2008 Yamaha R6
2013 Honda 250 CRF
1971 Norton 750 Commando
Alcon Brake Kits
Old 10-28-2006, 12:45 PM
I wonder if they could be 69S pistons. The 67-68S motors are listed with a CR of 9.8:1, while the 69S is listed with a CR of 9.9:1
Here's another pic of a 2.0S piston. It is clearly different than the set I have. However, The difference between the two looks bigger than 0.1 CR points.
I know there is someone on this board who will know the answer.
Tom Butler
1973 RSR Clone
Old 10-28-2006, 01:02 PM
tadd's Avatar
Those are 906 pistons for the extra tasty 10.3:1. Are they in spec?
tadd
Building molecues or building cars... you do get more of first in every batch. A mol of porsches anyone?
Old 10-28-2006, 06:06 PM
DW SD's Avatar
Tom,
Cool find! What are you up to? Are you building another engine?
Your nosey friend,
Doug
1971 RSR - interpretation
Old 10-28-2006, 08:30 PM
906 pistons...Wow!!!
I'll be offering these for sale in the classifieds along
with lots of her cool engine parts I recently purchased.
These have been inspected and are good to go. I wonder what they are worth?
Tom Butler
1973 RSR Clone
Old 10-29-2006, 01:16 AM
Alter Ego Racing
ErVikingo's Avatar
I can't really tell formt he pics but they look like 69 S pistons from here. Hopefully they are 906 though !
Porsche GT3 Cup Trophy Champion
Klub Sport Challenge Champion
Rolex Vintage Endurance Series Champion
PCA Club Racing Champion
National Vintage Racing Champion
Old 10-29-2006, 05:25 PM
Here's a pic of a set of 906 P's and C's I found by searching the forum.
They look just like the set I have. Does anyhave have a pic of a 69S piston?
I'd hate to sell mine as 906 pistons if they are really 69S.
Is there some way to tell them apart?
Tom Butler
1973 RSR Clone
Old 10-30-2006, 01:13 AM
tadd's Avatar
Tom:
You got 906 pistions. That peaked crown gives it away. Round that and you got S pistons. Then you loose valve pocket and you have E or L pistons, finally if you have little moonlets for valve clearence you are in T land. Simple as pie.
tadd
Edit: I think he was looking at the lower pic for that opinion...
Old 10-30-2006, 03:06 AM
914-6 GT Resource Page
ajserrano's Avatar
Can anyone help?
Hi Tom! Hope all is well. While looking for a couple of used 906 pistons myself, I came across your old post here. The way to best identify your MAHLE pistons is by their casting number.
MAHLE 906 Piston = 80P24 and/or 80P24 W1
MAHLE 911S (69) Piston = 80P26 E
I included the 69S because most forum posts I come across are erronously describing the 69S pistons as "906" when in fact they are not.
If by chance you do have some 80mm pistons with the MAHLE 80P24 casting number, please let me know if those are available for sale, I'm interested.
I'm currently trying to complete one or two sets and need some 906 pistons that are within the same weight group. See below...
This is my current inventory of MAHLE 906 Pistons and Alloy Cylinders.
Now look at the bottom row, I have identified five 906 pistons that are very close within the same weight group, I need to be within one gram from each other (ideally). Less material can be removed from the steel wrist pin to get closer to a match, but removing aluminum from the piston itself takes a whole lot more milling for just one gram which can compromise the integrety and reliability of the component.
The 906 MAHLE Casting Number 80P24 variation...
another 906 piston, same casting number...
Below are some details for an OEM NOS set of 69' 911S MAHLE pistons, the ones that most often get misslabeled as 906. This is a bit frustrating when you see it all over the boards.
(photo courtesy of Phil Hindley, UK)
Now my used set of 69S' 80mm MAHLE pistons, same casting number as Phil's...
One-Year ONLY 1969 Porsche 911S / MAHLE Casting # 80P26 E
Hope this helps some... AJSERRANO at MSN dot COM
1970 Porsche 914/6 GT > Recreation in progress... http://www.pbase.com/9146gt/my9146gt
1970 Porsche 914/6 > Crashed, driving while sleeping (not good!)
1974 Porsche 911 Carrera > Stolen, recovered in pieces
Old 07-13-2014, 08:54 PM
Armando
I have a few of these pistons left. Email or PM me for more details
Tom Butler
1973 RSR Clone
Old 07-16-2014, 04:54 AM
ajserrano's Avatar
email sent. Thanks Tom!
Old 07-16-2014, 06:37 AM
356RS's Avatar
Armando, Are these 80.94 the 81mm 906's?
Mark Jung
Bend, OR
MFI Werks.com
Old 07-16-2014, 08:53 AM
ajserrano's Avatar
Hi Mark! I just tried to call you...
Currently I have posted online a copy of the 1999 MAHLE Piston Casting Number Master List which is a later document and did not include the 906 variations, even the 907 which Phil and I suspect may be the very same part as the 906 pistons. Someone on this board probably has the earlier MAHLE Piston Casting Number Manual which could further shed light and answer some of our questions.
Old 07-16-2014, 09:14 AM
All the cylinders shown in this thread appear to be Biral.
Original 906 cylinders were Chromal, with dimpled chrome-plated bores.
Porsche used Chromal cylinders for racing engines well into the 917 era.
Jon B.
Vista, CA
Old 07-16-2014, 09:26 PM
ajserrano's Avatar
Here is a very nice complete set of early 906 cylinders which I'm using on my 906 engine build.
I'm now looking for a comparably nice set of 906 pistons to fill these barrels. MAHLE p/n 80P24...
Old 07-16-2014, 09:51 PM
ajserrano's Avatar
Technical Reference for 1968 on 911S...
Looking for similar document, but specifically for the MAHLE 906...
...photo courtesy Bernie Buschen...
Old 07-16-2014, 10:07 PM
Years ago I did a pre A 1500cc with chrome linings on aluminum cylinders. Gorgeous factory material.
Bruce
Old 07-17-2014, 03:06 AM
356RS's Avatar
Great information, Thanks Armando, Jon.
Mark Jung
Bend, OR
MFI Werks.com
Old 07-17-2014, 05:54 AM
Armando
So, apart from the casting number, what is the difference between the 69S and 906 pistons?
The domes look identical to me
Old 04-24-2016, 02:14 PM
