Cylinder Identification....different way?
I was putting together a shopping list and the JE pistons are really interesting...
So I need to know what type of cylinders I have. I jacked up the car and took a look see. And here is what I saw. Each cylinder had a number 1 with a triangle next to it with what appeared to be a 6 or an 8 inside the triangle. Does this identify the cylinder type? Is there a way to tell with out taking the motor apart? Chris |
It is very difficult to tell the difference between Alusil, Silimal and Nikasil.
The one on the cylinder is the diameter group (0,1,2,3) and the number in the triangle is either a 5 or a 6 and that number is the height group. All 2.7 cylinder types use these numbers. If you can see a rib running from top to bottom across the fins that cylinder would be a Kolbenschmidt Alusil cylinder. |
Can you tell
Can you tell with this picture?http://forums.pelicanparts.com/uploa...1162946789.jpg http://forums.pelicanparts.com/uploa...1162946807.jpg
Does anyone know if these are Alusil Cylinders? I am also in a similiar boat. It appears that there is a rib accross the cylinders in the first picture.
Someone had mentioned also that one of the cylinder types was a flatter outside finish than the other. |
found out what they were
I was prepared for them to be alusil, but found out they were Nikasil/mahle cylinders when I took the motor apart.
Good for me! you are really not going to know until you disassemble the motor. So do like I did and prepare for the worst case and hope for the best... |
| All times are GMT -8. The time now is 10:56 AM. |
