-   -   Re-use of rocker shaft cone/nut ? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/314693-re-use-rocker-shaft-cone-nut.html)
rlane 11-12-2006 09:59 AM
Is there agreement on reuse versus wholesale replacement of the soft cone washer/nuts that tighten the rocker arm shaft?
Eagledriver 11-12-2006 11:53 AM
Visual inspection and reuse normally.
rlane 11-12-2006 03:20 PM
so if the aluminum surface is smooth reuse?
Eagledriver 11-12-2006 03:46 PM
I know of no aluminum surface involved except for the bore in the cam tower. The bolts and cone nuts are steel. The rocker shafts are steel.
rlane 11-12-2006 05:12 PM
steel...very good. they just seemed very light as i cleaned them
Walt Fricke 11-12-2006 07:52 PM
It seems that after many R&Rs a ridge can develope at the fat end of the cones. This can prevent them from completing the wedging action, as it acts like a stop. I've taken to inspecting mine, and where present removing this ridge before reuse.
Walt Fricke
