user & abuser
advice on dyno results
http://forums.pelicanparts.com/porsche-911-technical-forum/315127-dyno-results-post2929070.html#post2929070
its a link to the thread i started under the technical forum, seems to be some worry about 35 degrees of advance on a twin plugged engine..... started around 29....this is total advance measured from the top set of plugs, bottom timing is not identical to top....
i would post the result, however i don't have the hard copy in my house in victoria (i'm at school), and no file.....
anyways... 260hp correct to 278 SAE hp which is close to 320 crank hp.... not bad, not great....was looking for about 15 more....
anyways...let me know what you 'experts' think....everyone is welcome, but henry,sw,streit, etc, your replies are mandatory!!!!!!!
vini vidi vici
Old 11-14-2006, 03:57 PM
