-   -   Need timing specs for 2.2 E cam (http://forums.pelicanparts.com/911-engine-rebuilding-forum/315913-need-timing-specs-2-2-e-cam.html)
billyboy 11-19-2006 08:27 AM
I need the timing specs for a 2.2 liter with "E" cams. I have installed an XDI electronic ignition and specifically need the advance at 400-1000 RPM , 3000 RPM and 8000 RPM. If anybody has this info or could direct me to where to find it, I would much appreciate it. thanks
