964 cylinders
Hi Guys,
I just wanted to know what the differences are between the 95 mm SC cylinders and the 964 cylinders. I accept that the 964 cylinders have a 100 mm bore and the spigot diameter is also larger. Overall dimensions of the 964 cylinders would be a great help. Thanks |
The biggest difference and the reason you can't use them on an earlier case is the stud spacing, SC/Carrera 3.0 and 3.2 use 86mm cylinder stud spacing, 964 and 993 use 90mm.
Bore centers were not changed |
Thanks Bill
Is it not possible to machine the stud holes in the cylinder, so that they can match the earlier type. I realise that the case spigots would need to be enlarged by 2 mm. Cheers |
| All times are GMT -8. The time now is 02:27 AM. |
