Oil Rings Not Marked Top - 2.2 Litre Goetze Rings
Rebuilding 2.2 Litre - Oil Ring is not marked top and has no printing on either side of the ring.
The oil ring looks the same no matter the orientation, can I assume that it does not matter which way the ring is installed??? Or am I missing something.
Old 11-19-2006, 04:35 PM
Air Medal or two
afterburn 549's Avatar
I belive there is no upside dwn to a oil ring
162 Assault Helicopter Co,(Vultures ) D troop 3/5 Air Cav. ( Bastard CAV) South of Saigon, U Minh Forest, Delta, and most parts in between.
Old 11-19-2006, 05:11 PM
CBRacerX's Avatar
My goezte oil rings did have a marking for "top" - it was hard to see but there.
Chris
https://dergarage.com
‘11 987.2 CS, '01 986S, '11 958S, '24 R1T, '87 Defender V8
Old 11-22-2006, 11:06 AM
Thanks ... but were these on a 2.2 engine ... I see some are marked (re: various images on the web) etc. but mine don't seem to be marked ... still not sure re: 2.2 T engine rings.
...James
Old 11-23-2006, 08:43 AM
Author of "101 Projects"
Wayne 962's Avatar
I believe that if there are no markings, then the ring should be able to be installed in either direction. Everyone I've seen looks symetrical to my eye, but I have never measured one to see if there is a side-to-side difference...
-Wayne
Old 11-23-2006, 01:14 PM
Thanks Wayne - yes they look symetrical, and seem the same, will carry on with my rebuild, ... spoke with another source this a.m. ... etc.
I wonder if Goetze has specs or advice ??? Not sure how to contact them or ???
Old 11-23-2006, 01:24 PM
