-   -   Cannot split case- Success and Failure Follow up (http://forums.pelicanparts.com/911-engine-rebuilding-forum/317464-cannot-split-case-success-failure-follow-up.html)
911 Wannabe 11-28-2006 03:27 PM
Thanks to all that responded and support. a combination of all your ideas worked well ! Found out why so difficult to split. Well, pictures say it all............
http://www.imagedump.com/index.cgi?pick=get&tp=474027
http://www.imagedump.com/index.cgi?pick=get&tp=474028
http://www.imagedump.com/index.cgi?pick=get&tp=474029
http://www.imagedump.com/index.cgi?pick=get&tp=474031
gtihop 11-29-2006 05:48 PM
OH Dear!! :eek:
cstreit 11-29-2006 07:14 PM
Yikes, spun a rod bearing then? (Can't quite tell if it's spun or just got hammered from the pics).
Did you suspect something, hence the teardown, or were you in there for another reason?
