-   -   FS - 3.0 SC Crankshaft (http://forums.pelicanparts.com/911-engine-rebuilding-forum/317565-fs-3-0-sc-crankshaft.html)
tom1394racing 11-29-2006 02:40 AM
This is a 3.0SC crankshaft that will need some repair.
The nose bearing journal measures 59.945 mm (0.015 below the wear limit) and shows signs of bearing damage. The #3 rod journal also shows signs of damage and measures at 52.900 mm (0.06 mm below the wear limit). The detailed photos show the condition of the journals.
All other journals and runout are within spec.
I figure the crankshaft repair will cost $300-400 so I am offering this crank for $400 plus shipping.
http://forums.pelicanparts.com/uploa...1164796727.jpg
http://forums.pelicanparts.com/uploa...1164796753.jpg
http://forums.pelicanparts.com/uploa...1164796773.jpg
