Life moves pretty fast.
Will an SC flywheel fit my 3.2 (G50 rubber clutch) ?
Tried a search for SC flywheel + 3.2 G50 but got over 700+ hits, is there a way to refine the search engine find exactly what you want ?
Twin plugging, you know it makes sense
HI The SC flywheel will fit , BUT are you still running the STD engine with the EFI or have you changed to carb's?, If you have the std injection the engine management box requires a reference and speed signal from the fly wheel which a SC do's not have, and the SC clutch/flywheel is for the 915 box and is smaller/different fitting to the flywheel for the G50 box .
regards mike |
