Fitting to connect oil hose
What type of fitting do I need to connect an AN-12 oil hose to the 22mm metric port on the bottom of the engine between cylinders 2 and 3?
i think pegasus racing has a fitting for an an-16 connection, maybe an an-12. i think they also make the fittings needed for the oil tank connection.
| All times are GMT -8. The time now is 08:35 PM. |
