...is my Daughter
Avery's Avatar
Spiral locks-how do you remove them?
I'm opening up a motor that has J&E's with the spiral loc type wrist pin locks. Is there a trick to removing these things? I have not really tried messing with them yet but I thought I ask before I start... TIA
Keep Going!
Felmir Singson RGruppe #479
"Living the rest of my life, one minute at a time"
Old 12-04-2006, 05:28 PM
tadd's Avatar
I always destroy them getting them out. I don't know if I am untalented or they are just designed that way. I use a dental probe (hook with a sharp end) and a pair of either 90 or 45 degree fine needle nose pliers. I've tried bent hemostats, but they dont have enough grip to muscle the ring out. I try to twist them along the circumfirence of the groove so it doesn't tear up the piston. Think like you are rolling up a sardeen (sp?) can lid with the key.
tadd
1967 912 with centerlocks… 10 years and still in pieces!
Old 12-06-2006, 12:26 PM
Super Moderator
cstreit's Avatar
I've never been able to get them out without destroying them. Then again, It's wise to replace them anyway. Pick out the end and then twist while pulling.
Chris
1996 993 RS Replica
2023 KTM 890 Adventure R
1971 Norton 750 Commando
Alcon Brake Kits
Old 12-06-2006, 04:03 PM
sww914's Avatar
I used a cutting torch, an air chisel, a 50 ton press and vice-grips, all at the same time. I ruined the case, the pistons, the pins and the rods, but I was able to save the locks.
Old 12-06-2006, 05:29 PM
...is my Daughter
Avery's Avatar
Thanks all.....the grab, yank, pull and destroy method is what I employed. Worked fine.
Keep Going!
Old 12-06-2006, 06:34 PM
