Need VE, AFR, Ignition Tables
I'm about to fire up a 3.2L short-stroke engine with Megasquirt EFI for the first time. Does anyone out there have a set of tables that I can use as a starting point. I expect to spend a fair amount of dyno time getting these dialed in. However, it will help if I can start with tables that are close.
The details - 9.5:1 CR, DC40-108 Cam, twin-plug, Jenvey 48mm throttle bodies, 1-5/8 inch headers. This is in my 914-6 conversion. |
I have tables for the stock SC with a 3.2L piston set, are these any help to you? I betting with you cam profile that they are not, but who knows.
Scott, Please send me your 3.2L SC tables. It would be a great place to start tuning.
I have some decent tables for a MegaSquirt II setup on a 930 engine (EDIS ignition & 50lb injectors). Since the tables cover the boosted pressure zones as well as the normal you can probably get more precision with Scott's. Let me know if you want a copy.
Scott R & mppickett:
I would also like to receive the Megasquirt tables. I am building a 911 SC 3.0L engine with turbocharger. Mike |
Mike, Scott, Bill,
I've been investigating various EFI options for my 88 930, can you tell me what modifications was required for the Megasquit and did it meet your expectations? Thanks Edmund. |
| All times are GMT -8. The time now is 04:51 PM. |
