If you had a Cayman, what engine would you build?
Let’s forget about crate GT3 engine because this thread is about building.
If you had a Cayman minus engine/transmission, what n/a engine would you build for track use? (no smog rules) |
well your in the water cooled engines i guess.
so you want to start with the gt (1-2-3) engine block, and i believe it can be pushed out to a total of 4L, theres no reason (unless it is then too weak) no to do that. toss on some nice ITB's, proably 50mm, with a sequential injection controller. (i think I would avoid varioram and such) add some side pipes so that they don't go sideways at all, just striaght towards the cloest edge of the vehicle. would be a beast... nice ot think about... |
How about a short stroke aircooled engine with horizontal fan? |
I would basically dissassemble the car and replace the needed parts leaving the unnessesary parts off. a 4 cam carrera 356 engine or the short stroke with a flat fan would give the car an old 904 feel. i would think the AC, water cooling parts, interior/trunk trim and bumper hardware would cut at least 400lbs off the total weight.
why on earth would you want to or even consider sticking an old air cooled motor into a cayman? just go buy yourself some 904kit car and stick your air cooled motor into that. I really do not understand why you would take a modern car and then backdate it in terms of technology with an air cooled motor.
edit. as far as a 4.0l engine goes I believe only cargraphic has done that. All the DP Porsche motors are 3.8litres and make scary power. Brumos ran a bastard 3.9l engine but it never worked properly. |
Just add two turbos and watch the competition cry foul.
Anyway there is no reason why a properly built watercooled race engine can't make close to 600hp in race trim. I doubt you will see that though because most Cayman/Boxster owners can't/won't afford the development work. If there was a race class that allowed full development of the Cayman engine series then you may see more cool stuff coming out . I looked into a Cayman for GT3 in ALMS or Grand AM, but right now there is not enough interest. Plus no one wants to hear the budget cost to show up for the first race. |
Twin turbo water boxer would make way more than 600hp. I would tell you what the unrestricted DP motors make but I cant. For reference a DP motor is a 3.8 litre RSR with no restrictors, the RSR's run two 29.2mm restrictors and make a healthy bunch. If you were to turbo any water boxer the numbers would be awesome. Jurgen Alzen is running a 3.8 litre twin turbo and a chopped 997 at Nardo to try and break 400km/h. The motor in said car makes over 1000bhp built by RS tuning. Stuff one in a Cayman and have fun. I have yet to see a forced induction Cayman but it would be interesting. Who cares though as Porsche wont race it. I would tell you all other secrets about Caymans being prepped for racing but I cannot. Just wait and see what some shops come up with.
Sorry, I meant an NA motor should make well over 600. Yeah I agree turbos should get you well over 1000hp in race trim. When you turbo these engines though we will find the flaws in a hurry. I have to wonder how much less durable the wet sump engines are.
I do not want a 904. For me, the Cayman is the best looking car in the world. I'm not biased on means of cooling.
Sorry not to have said how much power I'm looking for. Around 350 hp with 'getting-on-the-cam' characteristic. |
If you "only" want 350 you put a 911S 3.8 litre motor in and call it a day.
Or if you have some juice to spend call up Manthey or Alzen and have them put a GT3 engine in. I dont know what dyno's some ppl are using but what NA 6 cylinder porsche engine makes well over 600bhp? |
Not even in your dreams!!!Candy.
If a pushrod two valve 5.7litre engine can make 850HP in race trim, you better believe I can get 600HP out of an unrestricted, NA Porsche engine. Will it be cheap? NO. I figure it would be somewhere in the area of 60K to get it done. Yes it would last more than 10secs.
this car is an old Supercup, we rebodied with factory turbo bodywork so everything would fit nicely. We then turned the 4 cam wasserpumper into a twin turbo engine managed with Haltech E11. 700hp, 700 pound feet of torque. There is quite a bit more left in the engine. We have tuned conservatively (relatively) in order to help out the owners pocketbook lest he get overzealous. http://www.rudtnersracing.com/newgene.php |
I've yet to see a NA 911 engine fully developed.
actually, i'm kinda in the same league as turboteener here...
350's in nextal cup or w/e are making up to 800hp... from 5.7L carbed, pushrod, 2 valve, engine..... porsche's endurence car (rs spyder) is making good power ot of its 4.3L, according to the race anncouncers alot more then they admit to. but i'm far from and expert, expected another 20hp outta mine....lol.. cheers |
I have one of those inefficient Ford engines in my Mustang. Let's see, just two valves, yet 2.25"/1.88". Sure you say big and heavy and I'll grant you that....but with a roller cam, I'm still shifting at 7600rpm and can run it out till 8200 in top. With a stroke of 4.25" and 8000 rpm, I've got F1 engines of yesteryear covered for peak piston speed.
Power is air flow and no matter how exotic, it basically comes down to cubic inches x rpm x volumetric efficiency. The NASCAR boys are way over 100% VE so I'm not sure you can say simply that 4 valved boxster engines of some 30% smaller cc's are going to out produce. Unless your suggesting the Porsches are going to rev 30% higher which would put you at about 13k revs. Now were starting to talk F1 of only the late 90's and a little out of sportsman racing budgets. I'm going to wait for the 600hp NA Porsche engine in the 3.8 range. Just my .02 so I'm siding with Candelaria and Porschekid962 on this one. I'm certainly not doubting the brilliance of Porsche engines...just physics. |
I have seen Honda street engines making 140 percent VE at peak HP and Peak Torque. I assure you I can make that number with a Porsche race engine. The 2005 Porsche Leman engine was making 460HP with the restrictors in place. They were running it out to less than 9K. I would spin the engine to close to 10-10.5K and it could easily make 600hp. Plus with no restrictors the engine wouldn't have any trouble making that HP level.
Luke until you understand the physics please don't tell me it can't be done. The Six will loose some power in comparison without the extra two cylinders, but the extra friction would probably eat up the difference for the V8. The average weekend warrior wouldn't afford one Winston Cup motor, one Pro Stock engine, one ALMS engine, etc. That doesn't mean that kind of power level is not possible. The reason no one has made the power is because people keep telling them it can't be done and there is no race organization that would let it run. I would bet most of you guys believe 320HP is good from a 3.2 litre aircooled engine. |
i did not say that the engine wasn't a vary capable engine, and i did not say that the flat-6 would make more power then the nextal cup engines or w/e.... i said it would make 600, not the 800 those engines are making...
your reply was big time angry, and only because you read my response as angry... however, i am also a muscle car guy, i have a 69 chev step side with a ladder frame rear suspension, cammed up 327 making something like 300rwhp, turbo 400 with external cooler, .383 rear end, solo suspension....and this summer i am building a 500hp (forcheap if anyone here is a hotrod reader) 383 for it. but... with that said, if the older tech engines can make more then 120hp/L (expecially when the used to make 30-40hp/L) then i also believe that one of porsches advanced tech engines can also.... this is logic not physics... both of which i am qualifed to talk about. |
To Mr. Turboteener. The GT3 RSR motor is a 3.8 litre flat 6, breathing through two 29.2mm restrictors. I know how much power they make. The Grand Am DP motors are the same save for the fact the intake manifold is slightly different to accomodate an "open" intake. E.G. there is no intake restriction. These motors were just updated to rev to 9,250rpm and make a prodigious amount of power. Is the end result 600bhp? I cannot tell you as I promised the dyno operator I would not, is it impressive, very much so. That being said these motors have a 40 hour shelf life between builds. They use Ti rods, Ti valves, pistons, rods and cylinder liners are 40 hour replaceable pieces.
If you really think you can squeeze more power out of that motor while having a decent turnaround time I would be impressed. Bumping the displacement has been tried, they made impressive numbers but never lasted very long at all. One engine literally ate itself into bits. I have never seen a piston weld itself to a head before. The rod was a lump about the size of a large grape. Sure you could spend 60k. You can start with hollow stem Ferrera Ti valves, dont bother trying to get lighter rods, you might possibly find lighter pistons in the aftermarket from Cosworth or Accralite. Chambon might make you a lighter slightly longer stroke one off crank. Straight cut intermediate gears could be used to claw back some windage losses, go with Ti while your at it. Then you can spend weeks detailing the inside of the case, polishing it, boattailing the mains, polishing the oil pump etc. Then get custom coated main bearings, coated rod bearings, coat the valve faces too. Dont forget to pick up a stock GT3 RSR header since its inconel already. Then you can polish up the intake and exhaust ports on the heads a little bit. After that is all done call up the kids that built the "spike throttle body" for their college FSAE car and have them fab you a set for your 600+ na porsche motor. This is probably the best throttle body you can find. Then call up TAG/McLaren electronics and set yourself up with their motorsport injectors which are more powerful than any Porsche MFI pump and pickup their engine management system as well. Run two sets of injectors, direct and in the throttle spike. Now set yourself up with some Ti valves and Ti retainers, Ti lashcaps and you are almost there. Still need that custom cam. Better yet call up DelWest engineering and have them build you a one of pneumatic valvetrain so you can spin it to hell and back just like an F1 motor. A motor like that would make fantastic power numbers, I seriously doubt that it would last any longer than a GT3 RSR or DP motor in terms of being able to rebuild it at a reasonable cost. Sure Cargraphic built a 4.0 litre flat six but you start to press your luck at this point. The updated 964RS/GT3/DP case can handle things to a certain point but one way or another when you go that big something has to give. You almost might be better off spending money on a custom crank, case, heads, cylinders and building yourself a flat 8 at that point. Either way I wish you the best in your endeavours. Ryder |
Just to be clear. I'm not some mullet wearing muscle car touting man in anger. I hadn't the least anger. I rarely post on Ford racing forums and even less to Mustang Forums. I really have no reason to be angry in that Ford made a less efficient air pump than Porsche or XYZ. I still haven't forgiven them for not making a deep skirt block till recently :)
I was just playing devil's advocate. I didn't mean that it couldn't possibly done, only that for the funds of a team short of Lemans aspirations would seem quite difficult. I may not be an engineer, but I don't lack all knowledge of physics. AGAIN NO ANGER here. I didn't design either engine. I've worked on both....even a SBC but don't tell anyone. All's good for a debate. Actually, I've never been that impressed with specific outputs of 3.2 NA engines. Though some of the new head designs may change my views. |
Dang, I had a super nice post earlier today and the server dropped it somewhere between my computer and the forum. Oh well it was probably for the good.
Luke, I still don't forgive Ford for the 4.6 debacle. That engine is a waste of good engineering talent. You can't make much power from it in NA form. Bore is to small. I guess they made up for the eighties and 90s when they had Chevy on power with the 5.0. Now it is all Chevy. Give me an LSX over any kind of Ford. Anyway. Pkid? What kind of turn around do you need. The engine needs to last 25hours max for the shorter sprint races. Since Most guys don't race every weekend, turnaround would not be a problem. Cams and heads would hardly resemble the stock pieces. Plenty of welding and reshaping will bring out the best of the top end. I have many secrets to apply to the bottom end, that I can see are not being done right now. 600 can be done with lots of development. It will probably be the upper limit but it can be done. This is an unlimited engine there are no rules. SO whatever it takes to get it. This engine could live a whole season in club racing with proper maintenance and good driver behavior. |
What kind of turnaround? None at all but just to let you know all DP and RSR motors are built and rebuild on a 40 hour scale. Reason being is the small end of the Ti rods begin to elongate, the pistons go out of shape and the cylinders get wrecked. Keep in mind these are not 600 hp motors and are monitored very closely.
A 600hp 25 hour motor "might" be possible but you are talking about needing pro drivers to look after its well being. To be totally honest there really isnt a whole lot you can do with the bottom end to free up enough hp to breach 600. Boattailing is overrated and really cannot be done to the 3.6/3.8 964rs based RSR's and DP's due to vibration harmonics. Doing a "true" knife edge to the crank, not just the bs shaping of the bottom of the counterweight still wont bring the peak hp that high. The heads on those engines are pretty much at the limit. Yes you could polish them up a bit by hand but what would you get, 5hp max? I am not saying it cannot be done I am just saying it might be foolish to invest the time and effort in order to do so. If you started with a DP 3.8 motor, upped the compression slightly, had custom cams ground, swapped the injectors for TAG/McLaren parts, swapped the Bosch MS (which has thousands of maps) for a TAG/McLaren unit, had custom F1 style inconel merge collector headers made by an F1 or NHRA drag team, spent months hand detailing the heads and case, swapping out the large intake for single runners, you might get a 600hp engine. The problem becomes service intervals. I seriously doubt that a motor built to those specs would survive over 25 hours of club racing. Shifts are harder for one adding undue stress to the entire drivetrain, adrenaline often impedes sound judgement, it has happened to us all myself included. I truly believe a sub 4.0 litre 6 cylinder porsche motor NA could be built to make over 600 hp I just would not want to deal with the rebuild intervals. At that point it might become more cost efficient on a dollar per hp basis to build a very highly tuned twin turbo motor. Jurgen Alzen owned the ring with his gt2 DP composites widebody turbo until he wrote it off into a wall. Two twin scroll or two sequential turbos running inline with a very finely tuned engine management system could make a very reliable 800hp without resorting to very costly internals that would be needed in an NA motor. That being said I still wish you all the luck in seeing your motor to fruition. If you would like and inside tips let me know. |
Its not my engine. The OP ask what you would do. I agree you could boost the motor and make well above the goal without too much trouble.
Sorry those are not the internal mods I am referring to. I chose not to share what I know, but trust me it will make more power. I could make the same power level with steel rods. I know a manufacture that makes a steel rod that is very close to the weight of a comparable to a Ti rod. Durability will go down as HP goes up. There are people that don't mind spending that kind of money on a motor like this. I can find 40+hp in the heads. A properly designed plenum will make more power than ITBs. ITBs have a nice "drivability". All of the things you have listed are normal "bolt on" type approaches that will hit the limits you have seen. I prefer to look beyond that. |
| All times are GMT -8. The time now is 05:58 AM. |
