Go Back   Pelican Parts Technical BBS > 1- Porsche Technical Forums > 911 Engine Rebuilding Forum
UFLYICU
ZOA NOM's Avatar
Send a message via Yahoo to ZOA NOM
How do the camshaft cover plates come off?
I have removed all the sprockets and shims, but these covers won't budge.
Racer Rix Spec911.com #5 PRC Website
2005 Seal Grey 997 Carrera Coupe (Daily Driver)
1988 Venetian Blue Carrera (former Daily Driver)
1987 Venetian Blue Carrera Track Whore "Shellback Racing" (Porsche Racing Club Spec 911)
Old 12-18-2006, 05:57 PM
North Coast Cab's Avatar
Just did that today. You may have to pry the edge of the cover. It is pressed in with a o-ring and has a tight fit. Assume you removed the 3 allen head bolts already.
Also, depending on what you are doing you may want to tilt the motor to the left so nothing can fall inside the case.
1985.5 944 GTS
Old 12-18-2006, 06:08 PM
UFLYICU
ZOA NOM's Avatar
It's a full teardown/rebuild for a racecar. The three allens you mention aren't allens on mine if they are the ones that came out of the three holes shown. They were 10mm bolts. Would there be any harm in using a slide hammer lightly in each of the three holes, using some sort of tip that I could wedge into the holes?
Old 12-18-2006, 06:12 PM
len911's Avatar
just use the cam as a slide hammer. They are just hed in place by an o-ring.... Lou
'76 911 "Moneypenny" daily driver
'74 911 "JLo" IROC DE Car
'03 CRV, '02 Jeep Grand Cherokee
'03 Holiday Rambler Admiral SE, 30ft, 8.1l, 340HP, 455Ft#
http://www.nicotra4.hpshare.net/BasketCaseMotorsports/
Old 12-18-2006, 07:19 PM
UFLYICU
ZOA NOM's Avatar
Thanks Lou! I started to do just that, and thought better of it. I'll give it another go.
Old 12-18-2006, 07:52 PM
up-fixing der car(ma)
YTNUKLR's Avatar
Send a message via AIM to YTNUKLR
You need to remove the woodruff key on the cam. You'll notice a very small half-moon shaped little piece on the snout of the cam. Line up a small screw driver under the lip of the piece, and tap until it pops out enough to remove. Then, loosen the chain box nuts holding it onto the case and tap on the back side of the chain box to break the o-ring seal. Then, after you get the head stud nuts off, move the heads out about 1" from the cylinders, pop off the chain box, and remove the head assembly as one piece. I think it's easier to lay the heads down on a table and remove the rocker arms on the bench, as opposed to on the motor.
Good luck
Scott
Scott Kinder
kindersport @ gmail.com
Old 12-18-2006, 09:10 PM
Porschekid962's Avatar
Send a message via AIM to Porschekid962 Send a message via Yahoo to Porschekid962
What he said. Woodruff key, case nuts and your done. If it sticks use a rubber mallett and pop it off.
74 911s neverending story. two feet and a jetta for now.
Old 12-19-2006, 01:11 AM
ChrisBennet's Avatar
Dude,
Just push them out from the backside. A great tip I got from Grady.
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i Coupe
Old 12-19-2006, 09:18 AM
UFLYICU
ZOA NOM's Avatar
Got 'em. Thanks for the help. Perfect description, Scott. Worked exactly like you described.
Old 12-19-2006, 01:48 PM
Copyright 2018 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
