Roslin's Avatar
Question 915 transmission. 120 or 160 NM for M12x1.25 on the crownwheel ??
I found these two different values in two different books..
Roslin
Porsche 911 SC 3.0
Old 01-30-2007, 09:48 AM
MBEngineering's Avatar
HI Roslin check the bolt grade for the torque setting, from the list below.
the grade is on the top of the bolt 11.9 or 12.9, if there 12.9 use the LSD setting
regards mike
Regards mike
1983 911 SC sport, 1982 mini city
Old 01-30-2007, 12:48 PM
Roslin's Avatar
Thanks Mike.
The bolts are 12.9 so that might be 160NM.
The thin you send me are already powder coated, and fit in place on the engine. Only thing is the transmission now, and then i should be ready to put everything back in the car again YES !
(Is this the Bentley manual you are looking in ? )
Pictures following later.
Regards Roslin
Porsche 911 SC 3.0
Old 01-30-2007, 01:23 PM
HI Roslin no it's the workshop manual, why have you removed the bolts from the CW on the diff?? just check the bolts are the corect length for the diff carrier/crownwheel as 3 lengths are available!.
regards mike
Regards mike
Old 01-31-2007, 01:30 AM
Roslin's Avatar
Mike, The wheel was removed, when i discovered that one of the conical bearing have been lose on the journal.. so i felt it was essayer to handle the part without the crown-wheel, when it was repaired. I also used the surface to check the run-out during the circular grinding of the journal. A lot has been in bad condition in that transmission, but i think it will end up with good one.. :-)
Regards Roslin
Porsche 911 SC 3.0
Old 01-31-2007, 12:48 PM
Roslin's Avatar
... i saw in an old workshop manual, that the crown-wheel should be heated before install, but mine was easy to fit, so no press fit here..?
I do not know if the tolerance has been changed on newer models..
Roslin
Porsche 911 SC 3.0
Old 01-31-2007, 12:52 PM
