HKZ Bob's Avatar
Glyco Main Bearings oversize 0.25 outer diameter
Dear 911 folks,
I disassembled my 911 Crankcase and saw that my main bearings are 0.25mm oversize on the outer diameter. Original Porsche
Part No is: 911-101-901-60 for the whole SET.
Who knows the Glyco Part No for this SET ???
That would help.
Any ID to get a Set for an reasonable price?
Regards to all.
Old 01-04-2007, 03:59 AM
O/S bearings
What engine do you need them for ? and is the # 8 oversize ?
Mike Bruns
The two most useless things to a driver are the braking distance behind you and nine-tenths of a second ago.
Old 01-04-2007, 05:44 AM
MBEngineering's Avatar
HI your part No's have changed ;To 901 101 131 60 for the rear main x2 , 901 101 132 60 for the set of bearings and 901 103 138 63 for the nose/No8 bearing, if you double click on the highlighted text on the part No' you have, you will go on to the price/superseded list on your PET system. I have looked through my GLYCO book and they do not list any over size outside bearings, I have also rang one of my suppliers and thay do not list any, I have some other contacts that that could have some old stock , if you cannot get any over your end.
regards mike
Old 01-04-2007, 05:56 AM
HKZ Bob's Avatar
Thank you guys,
my old main bearings shows the porsche numbers.
901 131 60 & 901 132 60
If the bearings are hard to find or too much, IŽll look
for an std housing for an 2.7.
Old 01-04-2007, 11:15 AM
