304065's Avatar
Question about 3,0 Turbo Oil Pump and Sump Plate
I know that case modifications are required to use the 3,0 turbo oil pump due to its length. Is the bowl-type later sump plate a requirement also?
The early pump has a venturi on the bottom but still used a separate screen, unlike the Carrera pump which had the screen integral, necessitating use of the bowl-type later sump plate.
Thanks!
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 02-17-2007, 02:46 PM
You are correct the early turbo pump used the sump plate with the drain plug.
I have an NOS pump if you are interested.
Aaron Hatz
Flat Six, inc.
Follow us on Facebook
https://www.facebook.com/flatsixinc
Old 02-17-2007, 04:54 PM
