-   -   Lets play "ID THE CAM GAME!!!" Yay! (http://forums.pelicanparts.com/911-engine-rebuilding-forum/323023-lets-play-id-cam-game-yay.html)
BigD9146gt 01-04-2007 05:11 AM
Hello all,
I was hoping someone could help me identify these cams... I'm told they are a 908 grind (but obviously for a 911 with the four bearing 911 cam housings). The engine I picked up was a '72 2.4L with 92mm Mahles making it the 2.8L, stock 33mm intake port and 32mm exhaust port heads, MFI with a modified pump. I'm told it all worked really well together.
Part numbers are 911.105.137&138.0R
http://i97.photobucket.com/albums/l2...6/IMG_1617.jpg
I slapped these on the lathe and with a dial indicator it showed these have .450 lift and an obvious impressive duration.
http://i97.photobucket.com/albums/l2...6/IMG_1625.jpg
Thanks, Don.
Steve@Rennsport 01-04-2007 09:10 AM
Those are 3.0 RSR cams. :)
BigD9146gt 01-04-2007 10:15 PM
OOOOOO!!!! Thanks for the input Steve!
