Repack A T/o Bearing??
yes it is possible, I just did it last night. 1st remove circlip, 2nd press out clutch fork yoke, 3rd remove bearing and dust seal, 4th
remove w/ small straight blade screw driver the phenolic cage, 5th
wash out the factory grease and repack w/ Redline, 6th re space
bearing to fit phenolic cage and gently push cage back on being careful not to break cage, 7th reinstall dust shield and put bearing back in cup and then press in yoke until you can install circlip.
Keith Epperly
897 slant nose turbo look carrera cabriolet
Old 01-17-2007, 03:07 PM
PS,
T DID THIS TO GET RID OF THE MILKY LOOKING GREASE AND REPLACE IT W REDLINE HIGH TEMP. IT IS A NEW T/O BEARING
THAT I DON,T WANT SE SEE AGAIN FOR 9 YEARS YES I HAVE DECIDED TO SELL( WHEN I,M 65 ) BUT UNLESS I DIE ( ONE OF YOU GUYS WOULD STEAL IT FROM MY WIFE SINCE SEE HAS NO IDEA HOW MUCH CARE AND MONEY I'VE PUT INTO IT) IHOPE IT MAKES IT THAT FAR. JUST RESTARTING W/ 89,000 MILES.
KEITH EPPERLY
87 SLANT NOSE TURBO LOOK CARRERA CABRIOLET
Old 01-17-2007, 07:40 PM
