-   -   3.0 Turbo crank same as 2.4 crank? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/323942-3-0-turbo-crank-same-2-4-crank.html)
Kevin G. 01-09-2007 10:47 AM
I need a crankshaft for a 2.4 motor I will be building, and came across a 3.0 turbo crank that the owner says is interchangable the 2.4 / 2.7 crank.
Just need verification from someone who knows.
Thanks!
Kevin
Eagledriver 01-09-2007 10:57 AM
They are supposed to be the same. One quick way to check that it is probably the right one is to count the flywheel bolts. The 2.4/2.7 crank has a smaller flange with 6 bolts as opposed to the SC and later crank having a larger flange with 9 bolts.
-Andy
john walker's workshop 01-09-2007 11:39 AM
same.
tech 1 01-10-2007 08:00 AM
Same crank.
