-   -   Thought I was almost done... #6 piston hitting intake valve during valve adjustment. (http://forums.pelicanparts.com/911-engine-rebuilding-forum/324057-thought-i-almost-done-6-piston-hitting-intake-valve-during-valve-adjustment.html)
LeeH 01-12-2007 08:48 PM
Originally posted by john walker's workshop
a metric dial indicator is best. too many folks miscalculate when it's a US one.
I bet. Mine's digital... push a button to zero. Push a button for metric.
SP2 01-14-2007 09:32 AM
Re: Thought I was almost done... #6 piston hitting intake valve during valve adjustment.
Originally posted by LeeH
Ready for final valve adjustment. Set #1, Set # 6, turn crank... and it stops dead about 350 (NOT 110 as originally posted) degrees later. Back off #6 intake valve adjuster and it turns fine. What am I missing?
http://forums.pelicanparts.com/uploa...1166554101.gif
Lee,
Just to make sure, do you turn the crank clockwise 120 degrees after setting #1, before setting #6?
LeeH 01-14-2007 09:58 AM
Yep. I did it over and over with the same results.
