-   -   What do the 964 cams do to a 88 3.2? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/325879-what-do-964-cams-do-88-3-2-a.html)
axvel 01-20-2007 09:00 AM
ischmitz 01-21-2007 12:15 AM
wake it up a little....
ChrisBennet 01-21-2007 06:12 AM
Wake up the top end a little and make the valves a little more likely to hit the pistons. Stiffer valve springs are a good idea with this cam.
-Chris
88-diamondblue 01-21-2007 10:58 AM
Talk with John at www.drcamshafts.com. He will be able to tell you exactly what it will do for your engine. This is a very common to do during a top end or rebuild.
Jeff Alton 01-21-2007 03:38 PM
I have built a few 3.0 and 3.2 motors with 964 cams. Ingo has it right, they just wake the motor up a little. I liked them more in the 3.0 motors but they make a noticeable small improvement in both motors. I am not sure I would bother in a 3.2 unless the cams needed to be reground anyways, at that point it is a now cost upgrade.
Cheers
