-   -   Wurth Orange Sealant (http://forums.pelicanparts.com/911-engine-rebuilding-forum/328429-wurth-orange-sealant.html)
patkeefe 02-03-2007 09:01 AM
Anyone know of a good concoction for removing Wurth orange?
I had to take the cam towers off the heads on a 700 mile engine, and need to clean the old Wurth off. I'm trying to avoid stripping the heads down and hot tanking them. BTW, the heads are also off the engine.
TIA
Pat
tab tanner 02-03-2007 09:39 AM
Permatex make a gasket remover spray I have had great luck with it!!!!!!!!
ChrisBennet 02-03-2007 10:09 AM
Originally posted by tab tanner
Permatex make a gasket remover spray I have hade great luck with it!!!!!!!!
+1
If you look in the Factory manual is recommends a Loctite product - same part number as the Permatex product.
Works great but don't get it on anything painted like your engine stand. Don't ask me how I know...
-Chris
patkeefe 02-03-2007 10:45 AM
Thanks guys. I'll give it a try. That Wurth stuff sure does seal well.
Pat
72porscheman 02-10-2007 11:16 PM
Pat,
First of all, what year/engine is this? Age/wear can depend on how easily this stuff comes off. Wurth stills make excellent products today. You should check their website and see all their products.
Erick
patkeefe 02-11-2007 05:40 AM
Re: Wurth Orange Sealant
Erick, that Wurth stuff is pretty good. Their North American distributorship is actually in the next town over, so at least tech support is a local call.
It's a 78 3.0, with maybe 600-700 miles on a total rebuild.
The Permatex stuff works pretty well, but I still ended up taking the heads apart for cleaning and glass beading the sealing surfaces. The stuff was still orange, hasn't aged and heat cycled enough to turn black yet. Don't want to risk a leak, and I am NOT going to do this a third time. Changing the valve springs while I'm in there.
Pat
