-   -   84 Carrera Crankshaft 2-Row Pulley, Where is Z1? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/328645-84-carrera-crankshaft-2-row-pulley-where-z1.html)
Determined 02-04-2007 11:49 AM
Hi everyone,
My crankshaft pulley has several marks on both rows and I don't recall which one is Z1. There are no characters identifying which is what. On the inner pulley nearest the crankshaft there are a total of four marks that appear to be factory stamped. Two of them are about 20 degrees apart from each other and the other are much further away. Can someone please clarify where to look and tell me what all the marks are for. I am currently going through my pre-assembly check for piston to valve clearance. Pictures would be appreciated.
Thanks for your support!
Alex
dfink 02-04-2007 04:12 PM
Where the 2 marks are together Z1 is one on the left or the second mark as you rotate the crank. The other marks are 120* ea.
2.7RACER 02-04-2007 04:48 PM
http://forums.pelicanparts.com/uploa...1170640098.jpg
Z1 is the mark to the left.
Determined 02-04-2007 05:24 PM
Thank you both very much! I greatly appreciate it, I can now continue with my project. Great picture!
Best Regards,
Alex
