Cracked fan housing - repairable?
I'm rebuilding my '82SC engine. Everything's apart and I'm cleaning and bead blasting away. I noticed cracks around one of the studs on the fan housing. Is it possible to weld these? Is the fan housing magnesium or aluminum?
Thanks.
'82 911SC (Complete rebuild) Click here to go to the project website that chronicles the rebuild process |
Sadly at time of repair, their Mag. Yes it can be welded....I'd check around the airport or professional race shop. Many have had good luck with materials like JB Weld.
I still find it odd that so many shrouds crack in what seems like a fairly unstressed application. Before buying aftermarket, do a search there has been some quality issues with the Al ones.
Luke S. 72 RS spirit 2.7mfi, 73 3.2 Hotrod on steelies, 76 993 3.3efi TT, 86 trackrat, 91 C4s widebody,02 OLA winning 6GT2, 07 997TT, 72 914 v8,03 900 rwhp 996TT |
squidmarks
I would check with Casper Labs, they are into rebuilding piston airplane engines and contribute to this thread. They also sell a good set of head studs.
Al Morales 77 911 S (930 steel conversion) 88 BMW M3 79 Honda CBX |
