Distributor shaft clearance
Does anyone know the spec for the clearance of the distributor shaft up/down movement? I've got mine apart and it looks like there are shims/washers that are used to set the up/down clearance of the distributor shaft. It seems a bit sloppy - I want to see if I should add a shim to tighten it up.
Thanks.
Geoff
'82 911SC (Complete rebuild)
Click here to go to the project website that chronicles the rebuild process
Old 02-10-2007, 03:34 PM
