Distributor shaft clearance
Does anyone know the spec for the clearance of the distributor shaft up/down movement? I've got mine apart and it looks like there are shims/washers that are used to set the up/down clearance of the distributor shaft. It seems a bit sloppy - I want to see if I should add a shim to tighten it up.
Thanks. Geoff
'82 911SC (Complete rebuild) Click here to go to the project website that chronicles the rebuild process |
