-   -   Webcam 120/104 cam timing specs ??? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/329615-webcam-120-104-cam-timing-specs.html)
Avery 02-09-2007 10:48 PM
Does anyone have the cam timing specs for the subject Webcam please?
TIA
Steve@Rennsport 02-10-2007 08:22 AM
You betcha! :)
Time them to 5.2mm.
Avery 02-10-2007 08:24 AM
Alright! Is that with std valve lash or zero lash?
Thanks Steve.
canada911 02-10-2007 09:07 AM
120/104 set @5.2mm at .10mm lash as per Web-Cam valve timing info.
This cam works very well in my 3.4 with PMO carbs.
