1972_911T's Avatar
993 HE's Too Big for 3.0 MFI?
Im in the process of building a 3.0 MFI engine using large port SC heads. I have a set of 993 HE's with flipped flange for use on the early heads. Are these too large for use on a 3.0 MFI engine? I have heard that these engine benefit from some back pressure.
Regards Steve
1972 911t RS Styled
G50 conversion underway
1972t Resto Project - http://www.ddk-online.com/phpBB2/viewtopic.php?t=16695
Old 03-19-2007, 01:28 PM
jluetjen's Avatar
What sort of cams will you be running?
John
'69 911E
"It's a poor craftsman who blames their tools" -- Unknown
"Any suspension -- no matter how poorly designed -- can be made to work reasonably well if you just stop it from moving." -- Colin Chapman
Old 03-19-2007, 02:45 PM
Porschekid962's Avatar
Send a message via AIM to Porschekid962 Send a message via Yahoo to Porschekid962
FWIW the ID. of the 993 heat exchangers is identical to the SC RS and RSR 3.0 header which happens to be 42mm or 1 5/8th inches. If you have smoothed your heads out and are running some hot cams it should work out pretty well.
74 911s neverending story. two feet and a jetta for now.
Old 03-19-2007, 10:53 PM
