Less brakes, more gas!
euro911sc's Avatar
What happens at the mating point?
I've been reading a lot on port diameters, throttle plate sizes, and throttle body diameters, carb diameters, etc... I've read a lot about boring these out to specific diameters for a variety of engine volumes setups...
If I am correct, there are several parts that all mount up together to make up the 'pipe' from filter to combustion chamber. Some of what I have read indicates that each part would have different diameters. If they are bored out then there is no taper into the next part's different diameter and that leaves a step.
Shouldn't the mating surfaces of the parts be matched to remove the steps and smooth out the transition?
Best regards,
Michael
P.S. Pics looking down the pipes would be great so I could understand how they all go together
Michael
'82 Euro SC 'Track Rat' 22/29 Hollows, 22/22 Tarrets, Full ERPB F/R, Rennline Tri Brace, Glass bumpers, Pro 2000's, 5 pts, blah blah blah
'13 Cayenne GTS
Old 02-16-2007, 07:21 AM
neilca's Avatar
Steps in the inlet can be your friend or enemy depending on which way they face. If going down the throat the step creates a smaller throat, that is bad. It will cause turbulance and of course choke off the flow. If going down the throat the the step creates a larger throat that can help by reducing the amount of reversion. (definition: reversion- when the intake valve closes the flow is reversed in the inlet).
Hope that helps,
neilca
Old 02-16-2007, 10:11 AM
len911's Avatar
I'm including a couple of pictures (first 2) of what my 3.2l engine looked when I got it. The actual gaskets and spacers were not matched to the ports. I figured that you probably want a nice clean shot from the carbs into the cylinders. A little work with a Dremel tool made it nice and smooth (last 2 pics). Might be overkill, but why not do it right... Lou
'76 911 "Moneypenny" daily driver
'74 911 "JLo" IROC DE Car
'03 CRV, '02 Jeep Grand Cherokee
'03 Holiday Rambler Admiral SE, 30ft, 8.1l, 340HP, 455Ft#
http://www.nicotra4.hpshare.net/BasketCaseMotorsports/
Old 02-16-2007, 03:27 PM
euro911sc's Avatar
Yeah that's what I thought should be done. Though that part about reversion, I'm not sure I understand how a step prevents/helps with it unless it simply breaks up the wave?
Thanks for the pics Lou.
Best regards,
Michael
Michael
'13 Cayenne GTS
Old 02-16-2007, 07:29 PM
