-   -   Sealer for throughbolts ..should we use it? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/331009-sealer-throughbolts-should-we-use.html)
iangray100 02-18-2007 03:51 AM
Hi ,
Started my 964 rebuild and I see Waynes book says use RTV on the O-ring throughbolts. But I see from the recent threads , James and Kirk's that no sealer was used only Silicone 111 grease as a lubricant.
What's the opinion of others ..sealer or not or perhaps Threebond 1211 ?
thanks
Ian
mb911 02-18-2007 05:00 AM
I use dow corning 111 on my engines with no leaks. granted I have only done 4 911 engines but it has worked very well
MBruns 02-18-2007 07:01 AM
thru bolts
No sealer is advised, make sure that there is a chamfer at the hole (just enough to take the sharp edge off) so the o ring is not cut, DC 111 is good or some heavy assy. oil will work fine too.
Mike Bruns JBRacing.com
Eagledriver 02-18-2007 09:44 PM
Also a good idea to use the green viton o-rings instead of the blue silicon that comes with the gasket kits. I buy mine from German Precision but they should be available other places as well.
-Andy
iangray100 02-19-2007 11:06 AM
thanks guys, and I have green O- rings etc as Henry shipped me a full set of gaskets over to the UK for the rebuild.
304065 02-19-2007 04:05 PM
I have Wayne's book and think it's great but no silicone sealer is EVER going in contact with my oil system, of which the through-bolt holes are a part.
stevepaa 02-19-2007 04:13 PM
I have the same issue with putting sealer on the # 8 bearing o-ring groove. Do not put sealer where oil flows.
euro911sc 02-19-2007 05:27 PM
Hahhahaaa I love RTV...
NOT! yeah I don't think I'll ever be using RTV on an engine again... EVER. See what I found in mine (scroll down to the pic of the cam carrier... its a classic):
http://forums.pelicanparts.com/911-engine-rebuilding-forum/248146-holy-rtv-batman.html?highlight=RTV
*sigh*
Best regards,
Michael
