-   -   Henry Schmidt- help please (http://forums.pelicanparts.com/911-engine-rebuilding-forum/331104-henry-schmidt-help-please.html)
herman maire 02-18-2007 05:32 PM
Henry, I was trying to avoid bothering you but I am lost.....
A while ago you posted the best process on how to refinish the cooling fan+housing. I found the post and here is what you suggested-
BEAD BLAST WITH A/D GLASS BEAD.
THEN SPRAY WITH EAGLE ONE ETCHING MAG CLEANER.
DRY COMPLETELY, WIPE OFF WHITE RESIDUE WITH A CLEAN TOWEL.
LAST SPRAY WITH KRYLON SATIN CLEAR.
1- I got the A/D glass ( pretty expensive stuff, $60 55lbs bag!!??) . It looks like sugar right.
2- EAGLE ONE ETCHING MAG CLEANER- I tried looking everywhere for this stuff but nobody has a clue what I'm talking about. They have mag cleaner but never heard of "ETCHING" mag cleaner . I went to UAP...... What other option are there? would using thinner be OK then KRYLON SATIN CLEAR?
would really apreciate your info on this. for the others, here is a pic of one of Henrys awsome motors.
http://forums.pelicanparts.com/uploa...1171848699.jpg
BURN-BROS 02-18-2007 07:25 PM
Eagle One
Eagle One wesite
Any satin clear laquer and I am sure thinner is fine.SmileWavy
herman maire 02-19-2007 01:43 PM
Aaron,
thanks for the reply. I might have to end up buying it from your link... the problem with using thinner is that I think it will NOT have the shine that the rim cleaner will leave. I'm still waiting for Henry to chime in... hopefully soon.
Have you ever used thinner?
squidmarks 02-19-2007 03:57 PM
I also wanted to get the same look Henry shows. I found Eagle One Etching Mag Cleaner at Autozone. I have been bead-blasting my parts for quite awhile now. They look pretty nice after bead blasting, but I thought I'd try the Eagle One on them. Its rather nasty stuff (make sure you wear gloves) and I found it leaves a rather dull inconsistant finish. I ended up bead-blasting the part again (the fan) to restore it back to the nice finish bead blasting gives. After bead blasting, I've been using Dupli-Color Engine Enamel clear coat. It says its good up to 500F and has ceramic particles (presumably to increase its thermal conductivity). I am very happy with the finish it gives. Very smooth glossy finish. I put 2 coats of it on. You have to be careful, tho, as it runs easily as it is rather thin. It seems quite tough as well as parts that have been dried for a day appear to be very resistant to scratches.
I'm going to give the Mag cleaner another try tonight on a valve cover and let you know how it looks and maybe upload a few pics.
Geoff
squidmarks 02-19-2007 04:55 PM
Here's what happens when I try the Eagle One Etching Mag Cleaner.
Here's a valve cover that has been bead blasted, then the left side was treated with the mag cleaner. You can see that it has a tarnished, motled look to it whereas the non-treated right side looks better. Good news is that the tarnished look bead-blasts off again very easily.
I tried applying the mag cleaner a couple ways thinking I was doing it wrong. I tried spraying it on, leaving it sit for 5 min then washing it off with water. That gave the tarnished look, so I tried brushing it after spraying it on, but it gave no better results.
Henry, is it possible you reversed the steps? Do you use the mag cleaner to get the crap off the part, then bead blast it?
Geoff
http://forums.pelicanparts.com/uploa...1171932823.jpg
azasadny 02-19-2007 06:04 PM
Is Henry still around?
herman maire 02-19-2007 06:27 PM
he was yesterday ..... where you at henry? :)
herman maire 02-19-2007 06:36 PM
Geoff,
Did you try spraying it on, then taking a dry rag and ragging it off right away? would that result in that milky look too?
I am pretty sure you dont want this stuff sitting on it very long . From what I hear there are some pretty aggressive acids in this stuff . You also dont want to rinse it with water either, that will contaminate the painting surface ( I think) .
what bead are you using? the same A/D glass bead? SmileWavy
Also, when you did your fan... did you just clear coat right after you blasted it? what exactly did you do to clean it? If that works maybe i will give that a shot.
thanks
BURN-BROS 02-19-2007 07:31 PM
Geoff, If that valve cover is aluminum then yes it may become inconsistent in finish...especially a die cast piece. It will show the inconsistency of the "pour" of aluminum. Try a sand cast piece(any piece) and post your findings. I think magnesium yields a better overall result if it is die cast.
Herman, I misunderstood I thought the thinner was for cleaning purposes only...as opposed to water.
edit; I got to see the fan up-close and it was very even and looked great.
squidmarks 02-19-2007 07:45 PM
Herman, I did wash it off with water. I didn't try to wipe it off dry. I don't think you'd want to leave a residue of that corrosive stuff.
I usually wash parts in soapy water after bead blasting to make sure I get all the beads off. After washing, I dry them thoroughly before clear-coating.
I've tried the mag cleaner on parts similar to those that Henry showed on the picture of the engine above (chain housings and covers), but got the same inconsistant finish. I gotta think I'm doing it wrong, or Henry cleans them with the mag cleaner and then bead blasts them.
Geoff
Henry Schmidt 02-20-2007 07:08 AM
Aaron was correct with his identification of the Eagle one product.
My guess is that some of you experiencing problems either aren't looking for an original finish or you're leaving the product on the long.
The purpose of the etching product is to bring out the grain in the metal. Aluminum or magnesium fresh out of the mold does not look bright and shiny. It has a texture. That texture is what I am trying to reproduce with the Eagle One.
The picture of the valve cover is very close to what a new cover looks like.
Originality does not mean "it looks as good as it can" it means it look like new.
The fan on the early engine in the picture was finished using my process.
If you are unable to produce the finish you are looking for with this process, perhaps you should try something else.
Good luck.
Add on :http://forums.pelicanparts.com/uploa...1171989446.jpg
herman maire 02-20-2007 08:03 AM
thanks for the reply Henry,
I am trying to get the same look in your pic above so I am not trying to make it shinny. When you spray on the eagle one product do you wipe it off right away with a dry rag then clear coat it? Or am I missing a few steps.
Thanks again :)
Henry Schmidt 02-20-2007 08:26 AM
Follow the directions on the bottle.
Spray on, wait 30 to 60 seconds (this is the tricky part, too long and it turns black) then rinse with water and dry. Then spray on the Krylon Matte Finish clear (1311).
This is not rocket science. If it doesn't come out perfect for you, perhaps you set the bar too high.
Good luck
BReyes 02-20-2007 05:31 PM
Question: I have a fan housing that I took apart and had the pully cad yellow anodized.
Is there a source for the bolts so I can bolt the pully half back on to the fan? Is there cad yellow or black?
Thanks.
herman maire 02-21-2007 06:02 AM
Good luck
Thanks Henry... I know its not "rocket science" but when you have never done it, I just want to get it right the first time.
Thanks again SmileWavy
herman maire 02-21-2007 06:05 AM
Thanks.
Pelican does not list this part so you going to have to call that one in.... I am sure they can get the pully bolts. Let me know what you find out.
Henry Schmidt 02-21-2007 06:40 AM
The original fan is held in place by rivets not bolts.
Through the years we have learned that we could replace the rivets with flat head allen bolts.
The pulley must be prepped for the bolt prior to plating. This prep consists of countersinking / tapering the holes so that the flat head bolts would be flush when the job is completed.
I believe the countersink is 82 degrees.
The bolts can be purchased from any hardware supply. We use 1/4 20 flat head allen bolts. We also back up the bolt with a prevailing torque lock nut.
I have never found these allen bolts in gold cad so we send out a box to be plated so they match the pulley.
http://forums.pelicanparts.com/uploa...1172069030.jpg
IXjamesXI 07-07-2015 05:51 PM
I gave it a try.. I like the results. Does the fan need to be balanced now that I have futzed with it?
http://forums.pelicanparts.com/uploa...1436316626.jpg
http://forums.pelicanparts.com/uploa...1436316665.jpg
Henry Schmidt 07-08-2015 11:17 AM
No balancing should be required.
Our fan restoration has taken on a whole new process.
We now replace the rivets with custom made rivets.
We have a new colorizing process and we resurface the pulley for increased belt life.
http://forums.pelicanparts.com/uploa...1436378843.jpg
http://forums.pelicanparts.com/uploa...1436378807.jpg
http://forums.pelicanparts.com/uploa...1436378821.jpg
http://forums.pelicanparts.com/uploa...1436378876.jpg
http://forums.pelicanparts.com/uploa...1436378903.jpg
http://forums.pelicanparts.com/uploa...1436379293.jpg
We also offer an aluminum pulley assembly for racing applications.
http://forums.pelicanparts.com/uploa...1436379428.jpg
chris_seven 07-08-2015 12:01 PM
We have had a tungsten carbide die made by a specialist Aerospace Rivet manufacturer and they have produced a batch of 2000 rivets on our behalf.
We sent them a fan and centre to produce the rivet from.
We then made a setting tool - this is version 2
http://i197.photobucket.com/albums/a...ps3hq5wpcs.jpg
The first version was slightly out in terms of the pitch of the rivets so we made better measurements using a CMM.
http://i197.photobucket.com/albums/a...psvtdvf7ai.jpg
The fixture aligns the rivets and is fitted with hardened dowels to react the setting force.
http://i197.photobucket.com/albums/a...ps15fzhfja.jpg
We then bolt it up to prevent movement and set the rivets using a No6 Flypress.
IXjamesXI 07-08-2015 01:54 PM
Henry, thanks for your response. The "new" finish on your fan looks just like what I imagine the original finish would have been. Closely guarded secret I am sure. Chris, I am admiring your set up also. Are there enough people out there with fans who need refinishing that it pays to make up that kind of tooling etc? Apparently so. Neat. I encourage other home DIY'ers like me to try Henry's method outlined at the beginning of this thread. I am pretty satisfied with the appearance, but then again I am pretty satisfied with the looks of any fan that isn't red or yellow powder coated.
chris_seven 07-08-2015 11:02 PM
We do around 10 fans a year - not too many but we wanted to do the job well. We have also sold around 3 of the fixtures so all in all it hasn't been too bad an exercise.
Chromating fans does give an original appearance but the problem with some of the early fans can be pitting around the hub.
This doesn't really show up until they are bead blasted and cleaned but spoils the look and then they need painting.
Henry Schmidt 07-09-2015 04:00 AM
Hi Chris. We haven't tried a "chromating" process as you mention. Do you have any pictures of this process?
chris_seven 07-09-2015 04:42 AM
Henry,
its a simple dip process similar to Alodine treatment for Aluminium - the chemicals are a bit unpleasant and we use them in a heated bath.
Henkel make an Alodine for Magnesium that is sold in the USA but is not imported into Europe as some of the chemicals have been banned.
http://www.silmid.com/MetaFiles/Silmid/04/0436ddf4-1545-4328-86e8-b1ce8d17ef72.pdf
It may now be sold as Bonderite.
BONDERITE M-CR MAGNESIUM CHROMATE COATING CASE - Henkel
We have been using a Tri-Valent solution that we buy from Trimite that works reasonably well.
We treat MFI throttle bodes after machining to protect the bores from further corrosion and then paint using an Epoxy paint specially developed for Magnesium that we buy from Indestructible Paints in Birmingham (UK)
Henry Schmidt 07-09-2015 05:15 AM
Any pictures of the end result you can share with us?
chris_seven 07-09-2015 06:26 AM
I will get one sorted out but I am not sure if it will match the Alodine which I would use if I could.
RSTarga 07-09-2015 10:06 AM
I don't know if this is the same as chris's , but here is my fan that was chromated and then wiped down with HHS2000.
The raw Chromate can be lighter or darker depending on dip time.http://forums.pelicanparts.com/uploa...1436461557.jpg
RobFrost 06-17-2024 03:38 AM
The original rivets appear to my eye to be aluminium. Is this correct, and do you replace with aluminium?
Henry Schmidt 06-17-2024 06:43 AM
The original rivets are aluminum as are the replacements we use.
We make rivets and fan centers as well.
http://forums.pelicanparts.com/uploa...1718631774.JPG
winders 06-17-2024 08:43 AM
Rob,
Sadly, Chris passed away several years ago now. He was a great person along with being a great resource to the community.
Henry Schmidt 06-17-2024 02:03 PM
Chris was a great guy. I met him nearly 20 years ago when he contracted Supertec to build two vintage rally engines (one, won the European championship) and one ended up powering a personal friend's car. I miss his knowledge and banter. He used to tease me over head studs.
http://forums.pelicanparts.com/uploa...1718657909.JPG
I never met the customers but he sent me this picture.
Locker537 06-17-2024 02:13 PM
That is awesome. Thank you for sharing.
Turbo_pro 06-18-2024 09:38 AM
Wow, memory lane Hank.
You just finished my 3.5 when you started those engines.
My 3.5 is still running strong 20 years and 72K later.
http://forums.pelicanparts.com/uploa...1718728308.JPG
