Alternator rebuild
Just thought I'd share my alternator rebuild. I'm in the process of rebuilding my '82SC engine. The alternator works fine, but it, like the rest of this engine, is a filthy oxidized mess. It needed to be disassembled and cleaned. It gave me a chance to check the bearings and brushes, too.
Here's the ugly beast before: http://forums.pelicanparts.com/uploa...1171935544.jpg http://forums.pelicanparts.com/uploa...1171935580.jpg |
These winding wires need to be de-soldered before the diode support assy can be removed.
http://forums.pelicanparts.com/uploa...1171935640.jpg I had a small soldering iron, so it took a little while to get them off, but eventually they released: http://forums.pelicanparts.com/uploa...1171935692.jpg Here's after the diode support assy had been removed: http://forums.pelicanparts.com/uploa...1171935816.jpg Then the voltage regulator/brush assy was removed: http://forums.pelicanparts.com/uploa...1171935856.jpg The top casing was pulled off: http://forums.pelicanparts.com/uploa...1171935900.jpg Here's it completely dissassembled: http://forums.pelicanparts.com/uploa...1171935924.jpg And here's the same parts after cleaning, bead-blasting, clear-coating (the rotor and coil were only cleaned), the bearings re-packed: http://forums.pelicanparts.com/uploa...1171936014.jpg Everything back together: http://forums.pelicanparts.com/uploa...1171936045.jpg http://forums.pelicanparts.com/uploa...1171936061.jpg |
Nice! I'm jealous. :)
WOW!!! Is that only clear laquer sprayed on the outer casings of the alternator? Specifically, did the metal go from that mousey grey to that nice bright silver color with the help of the laquer??
#2: Are those new thru-bolts or the old ones bead blasted? #3: What kind of a cleaning tank system and bead blasting set up is working for you?? Thanks, Bob in Plymouth,MA Maybe I can self invite myself up to your shop to check how you are getting these great results? ;-) Thanks! Bob |
Bob,
Bead-blasting is what really does the job on tarnished parts. Although the bead-blasting gives a very nice matte finish, to prevent oxidation/tarnishing again I clear-coat with either the Dupli-color engine enamel clear coat (rated to 500F) for a glossy finish or the Dupli-color clear coat caliper spray for more of a matte finish. The alternater was sprayed with the clear engine enamel. I have a 40gal parts washer with a water-based cleaner. I use that just to get the dirt, oil and grease off the parts. The bolts are the original one that were bead-blasted. Sure, come buy for a visit sometime. I'm close to Worcester. Send me an email (geoff.gerhardt@gmail.com) or pm. Geoff |
Wow, if the factory had ever lavished that kind of attention on the Paris-Rhones perhaps they would have had a longer service life!
Wishing you many miles and millions of coulombs of happiness. |
| All times are GMT -8. The time now is 05:10 AM. |
