Eye of the Toiger
matty74's Avatar
46mm intake ports
Hi there,
I have a stock 2.7 which I want to re-build to the following spec.
2.7 L
GE 60 Cams
40MM webers
JE Pistons
Now my question is about valve size the stock motor runs 32mm
intake.
I know some one who can sell me a set of 46/40 heads, is this size to big for my set up? how will it change the way the car drives?
help greatly appricated
Matt
http://www.aircooled.com.au
1973 911 RSR clone powered by 77 3.0 turbo
Old 04-01-2007, 05:29 PM
Matt:
Those heads would be FAR too big for a 2.7 with those cams, even a full-on 300+ HP race engine,...
I think you'll do OK with 38mm intake and 36 mm exhaust ports with the proper headers and muffler system. Use stock intake valves (or maybe 2mm larger) and stock exhaust valves. Seats must be cut to fit.
There are some custom valves that outflow the OEM ones, too.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 04-01-2007, 06:27 PM
Eye of the Toiger
matty74's Avatar
I think I got it wrong, the Valves are 46 mm intake and 40 mm exhaust.
The guy who has them said they are used on the 2.7 RS engine
Old 04-01-2007, 06:48 PM
Oohhh,....thats different, yes?
46/40 valves work great on RS spec engines with 36mm & 35mm ports.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
Old 04-01-2007, 11:15 PM
I am in the same boat,
76' 2.7 with 9.5 JEs, Mod s cams and 40mm webbers.
The question is 38mm/36mm or 36mm/35mm ports?
O22$pa
70 porsche 911t
52 mgtd
Old 04-04-2007, 12:33 PM
Eye of the Toiger
matty74's Avatar
911 104 342 2R are the 36mm ports
911 104 345 2R are the 32mm ports
Old 04-04-2007, 04:05 PM
