-   -   Cylinder size code question (http://forums.pelicanparts.com/911-engine-rebuilding-forum/332558-cylinder-size-code-question.html)
ouo1006 02-26-2007 07:49 AM
Is it permissible to mix in a number 3 Size Code cylinder in an engine were all the other cylinders are Size Code 1?
Henry Schmidt 02-26-2007 11:47 AM
Re: Cylinder size code question
As long as the piston matches the cylinder it's OK.
Perfect? no, but you will not notice a performance difference.
It is not advised to run a 1 piston in a 3 cylinder.
ouo1006 02-26-2007 01:13 PM
Thanks Henry. Yes I will be running a size 3 piston in the size 3 cylinder.
