-   -   964 Piston ring gaps (http://forums.pelicanparts.com/911-engine-rebuilding-forum/332605-964-piston-ring-gaps.html)
iangray100 02-26-2007 12:46 PM
Hi ,
Does anyone know what the Piston ring gaps readings should be for a MY92 964.
I'm fitting some new ring and want to check the ring gaps before fitment.
thanks
Ian
iangray100 02-26-2007 01:49 PM
Found it.... for a 964 C2/C4:
Top and bottom compression ring 0.15-0.3mm were limit 0.8mm
Oil ring 0.15-0.3mm were limit 1.0mm
Henry Schmidt 02-26-2007 08:52 PM
Those specs are correct.
Here's an interesting question.
0.15-0.3mm wear limit 0.8mm. How many engine builders would install a ring with .030" gap? . Yet that is the top limit Porsche says is usable.
iangray100 02-27-2007 01:46 PM
Henry , is that a limit that is not documented, as it seems very tight to me ..if the spec i have found are correct for a 964.
PS: the full gasket I ordered off you a few months ago will be used very soon on the 964 rebuild....
thanks
Ian
Eagledriver 02-27-2007 07:04 PM
Last set of "new" Goetz rings I bought were close to the wear limit. I ended up using the old ones as they were better than the new ones.
-Andy
