Testing Ignition Coil
Can someone tell me how to check a coil to see if it is working properly. What are the resistance readings at the terminals? What should the ohm meter read when testing the continuity of the coil to distributor wire? Porsche 1977 911S, 2.7litre engine.
Old 03-17-2007, 09:31 PM
