-   -   993 Pump into a 3.2? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/335109-993-pump-into-3-2-a.html)
Lukesportsman 03-11-2007 08:17 PM
Is this difficult? Anything other than checking clearances on reciprocating mass? Will this be nearly a bolt in upgrade..just trying to maximize flow with the TT's planned for the 3.2 case.
Any advise or suggestions/cautions?
Thanks in advance,
Lukesportsman 03-12-2007 07:13 PM
No one knows?
Lukesportsman 03-17-2007 07:34 PM
come on, no ones done this? I was told to upgrade the 3.2 oiling for a turbo and I thought this would be a good route.
Does anyone know of any clearance issues or specail fitting requirements?
Flat Six, Inc. 03-17-2007 08:09 PM
Should work fine......bolt away.
Steve@Rennsport 03-17-2007 09:54 PM
Luke:
Just my opinion, but I'd be using either a 930 or GT-3R oil pump for any Turbo motor that has more HP than stock level.
3.6 pumps are magnesium and expand more than the aluminum/iron 930 or all-aluminum GT-3R ones. Further, the GT-3R ones do a better job of scavenging the sump which is so important on a forced-induction motor.
Flat Six, Inc. 03-17-2007 10:16 PM
I agree......ideally use a 930 or GT3R pump.
The GT3R pump in an earlier 3.0L case took some dorkin' around to fit right but it wasn't that big-a-deal.......not sure how they fit in the 3.2L case?
Steve?....:)
