Hello does someone of you have the Glyco part no of the 2.4/2.7 rod bearings.
attached the part number for the 2.2. bob
HI is this any good??
or this? I know it says turbo at the top of the page , the rest of the speck's on the bottom of the other page for 71>2.4 and 78>77 2.7 engines. regards mike
Regards mike 1983 911 SC sport, 1982 mini city |
Mike
Thanks a lot for your help. I asumme that 2.4 2.7 uses the same as 3.0 liter Bob |
HI 76-77 3.0Lt Carrera and the 3.0Lt turbo use the same bearings as the 2.4-2.7 , small 6 bolt crank. some of the mains change with the locating tabs.
regards mike
