Did I screw this up???
I was cleaning the top of the piston with Scotch Brite and came to close to the edge. Will it be alright???
Thanks Rick http://forums.pelicanparts.com/uploa...1173749598.jpg |
Its ok, The top dia. is smaller anyhow.
Bill |
Thanks for the info, one less thing to worry about. Now onto the case sealing :-(
Rick |
You should be fine, I also had my sides coated with a dry film lubricant.
Good luck, Alex |
| All times are GMT -8. The time now is 04:17 AM. |
