Custom trumpets (where can i get some?)
I have been searching the internet for some intake trumpets. I have Jenvey's on the car now but this is for a little side project of mine. I need something from 200-260mm in length and about 42-50mm I.D. at the base. Does anyone know where I could find something like this?
Also does anyone have a drawing of an air cooled porsche head? Not just the exploded diagram view but a working drawing with dimensions and all views? Any help would be much appreciated. Cheers |
I found a few options but nothing breathtaking or in the exact dimensions that I need. While we are on it, does anyone have some trashed/non repairable 3.2 litre heads laying around they dont want anymore?
If these are for the Jenveys, my machinest makes custom ones.... I also have a set of 3.2 heads but they are repairable, just not great....
Cheers |
I measured my Jenvey trumpets at 3.5". What do you have on yours currently? Did you need six, as I might switch out to shorter ones to make air filter choices easier.
OT, what air filters are you running on your Jenveys? |
On mine I run the piper cross ones....
Cheers |
These are not really the dimensions you mention but we have these in stock. High butterfly injection stacks.
http://forums.pelicanparts.com/uploa...1173892392.jpg http://forums.pelicanparts.com/uploa...1173892415.jpg Please check with Pelican to see if they offer something comparable for sale. With these as with all parts Pelican Parts should be your first stop. http://forums.pelicanparts.com/uploa...1173892459.jpg |
You may want to check here - http://www.velocity-of-sound.com/
Luke I am running ITG air filters on the Jenvey setup. None of the horns/trumpets/tubes Jenvey or TWM make are going to be long enough for what I am trying to do. Interestingly enough I got more useful results by searching "ram tubes" than almost anything else I could think of.
The velocity of sound stuff is going to be the closest to what I "need" for this little adventure. Thank you gentelmen and will keep you posted as things get more interesting. |
You can also check with Kinsler Fuel Injection. Here is a page from their catalog - http://kinsler.com/Cat_31_Web_HTMLs/0201234_screen27.html
| All times are GMT -8. The time now is 11:23 PM. |
