#8 Bearing Seal
Does anyone have any good "magic tricks" for getting the #8 bearing seal removed? Bearing is off of the engine, just can't get the seal off In the middle of an engine rebuild. Thanks in advance!
Mark
1987 Carrera
2018 GMC Sierra Denali 2500 Duramax
2012 Harley Davidson FLHX Street Glide
Old 03-28-2007, 02:34 AM
Prop it up on some blocks and drive the seal out from behind. Be carefull not to damage the bearing. The open jaws of a vice wound work if you covered them with some scraps of aluminum to protect the bearing.
-Andy
Old 03-28-2007, 08:06 PM
