Would not hurt at all, probably will not help much either. At this point, the biggest benefit is to you feeling more confident (which does count for a lot, not trying to be facetious) about that part of your engine assembly. But, did you mean half a thousands, or 5 thousands?
Half a thou. .0005".
Piston orientation
Stock pistons, there is no dome, there are no valve relief cuts.
With .0005" wear on the pistons, why bother with cylinder replating? By memory that would leave another .003" before considered worn out. Did the bores distort dramatically or have very serious scuff marks in them?
The cylinders were not round enough. Common problem for the 930 cylinders.
Tell me about it, not the most stable design not having fins all the way around on a very thin casting. That is why I ended up going with JB Racing fully finned cylinders with steel liners.
| All times are GMT -8. The time now is 11:57 AM. |
