Rubber trim for engine compartment
Hi All,
I've searched but could not find the part number for the ~3 inch wide trim that attaches to the body and creates seal around the engine compartment when the engine is mounted. The trim I have in the car now appears to be three piece set and each piece helps build the seal. Anyone know where I can find a replacement part? Thanks, V. |
91150411102-M136
91150411302-M136 I just replaced mine, what a difference.http://www.pelicanparts.com/cgi-bin/ksearch/PEL_search.cgi?command=show_part_page&please_wait= N&make=POR&model=911E§ion=BDYsl2&page=2&bookma rk=13&part_number=911-504-111-02-M136 |
Thanks Steve. I just put a set on order.
That seal is a bear to install. I highly recommend using silicone spray if you chose not to bend and re-pinch the metal channel that holds the seal in place.
| All times are GMT -8. The time now is 11:39 AM. |
